[GRASS5] vt100 error with osx + xterm error
John Huddleston jhudd at lamar.colostate.edu
Mon Feb 19 16:28:29 EST 2001
Well, I fixed the error for Cygwin.  It turned out that the
/usr/lib/terminfo directory was a symbolic link to the
./share/terminfo directory.   I removed the symbolic
link, moved the share terminfo directory to /usr/lib and
created a symbolic link from share to ../lib for the
terminfo directory.   No more error message.  That's
a weird one.   It might be because I am using the X-win32
server from StarNET.  Programs compiled outside of
Cygwin do not recognize the Cygwin symbolic links.  The
xfree binary should work OK.
John Huddleston
----- Original Message -----
From: "Justin Hickey" <jhickey at hpcc.nectec.or.th>
To: <grass5 at geog.uni-hannover.de>
Sent: Monday, February 19, 2001 12:34 AM
Subject: Re: [GRASS5] vt100 error with osx + xterm error
> Hi Andy
> andy agena wrote:
> > I should add that the 'vt100' error is when I 'grass5' in an Aqua
> > terminal. If I'm in a xwindows terminal via vncviewer, the error is
> > that it can't open 'xterm.'
> > Jeshua's binaries installed, but I get the following when starting
> > GRASS:
> > Starting GRASS ..
> > Error opening terminal: vt100.
> > Invalid resource file, removing /var/root/.grassrc5
> I don't think I can help much, but looking at the code, my guess is that
> the UNIX function initscr() (called within the vask library) is finding
> an error. This function exits the program if there is an error after
> printing a message (the "Error opening terminal:" message seems to be a
> UNIX message not a Grass message). I'm not sure, but it appears that you
> have a system problem as opposed to a grass problem. Anyone know more
> about the initscr() call and how it works with the vask library?
> Sorry I couldn't be of much help.
> Sincerely,
> Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
> High Performance Computing Center
> National Electronics and Computer Technology Center (NECTEC)
> Bangkok, Thailand
> People who think they know everything are very irritating to those
> of us who do.  ---Anonymous
> Jazz and Trek Rule!!!
> If you want to unsubscribe from GRASS Development Team mailing list write
to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
If you want to unsubscribe from GRASS Development Team mailing list write to:
