[GRASS5] Module file sizes
David D Gray ddgray at armadce.demon.co.uk
Mon Feb 19 16:51:12 EST 2001
Rich Shepard wrote:
>   I just added v.in.mif to /usr/local/grass5/bin and discovered that almost
> all of the files there are of the same size: 79244 bytes. A couple (other
> than v.in.mif that weighs in at 696526 bytes) are larger: r.weighted.cn and
> r.agnps50.run; one (tcltkgrass) is much smaller. Is it usual for different
> modules to compile to the same size?
> Just curious,
> Rich
Rich, yes sorry. In our private communication I misinformed you. The
contents of .../grass5/bin are all hard links to .../etc/front.end, (not
the actual module binary), but with the name of the called module. So
these links are all the same size.
This organisation allows a module to be called and then sort out whether
it uses the binary from the cmd/ or inter/ directory to handle the data.
No options -> use interactive; with options->use command line parser.
The module should be in .../grass5/etc/bin/cmd and make a hard link
etc/front.end <-> bin/v.in.mif.
The size of v.in.mif is mainly due to the generated scanner, which is
large but fast.
Regards
David
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
