[GRASS5] Monitor map scale program finished
Eric G. Miller
egm2 at jps.net
Sun Feb 18 18:47:09 EST 2001
On Wed, Feb 14, 2001 at 03:24:35PM +0000, Markus Neteler wrote:
> Hi Eric,
> after spending more time on this I have finished the
> small "scale" program. Example run:
> Xserver screen resolution: x:90.060942 dpi y:95.976384 dpi
> Map parameters:
> True map size: we_meters: 5277.500000 ns_meters: 4032.500000
> Pixel numbers used in screen: ns: 961.228802 we:1258.000000
> Map rows: 1613 map cols: 2111
> Map height in meter: 0.271097
> Map width in meter: 0.332928
> Current map scale (note: Xserver x_res != y_res):
> y-scale: 1:14874.773747
> x-scale: 1:15851.788407
> Hey, my first Xserver-related software :-)
> Find attached:
> scale2.tar,gz
> BTW: The Xserver x_res != y_res is really odd! I hope all the GRASS
> display/measure modules take care of this. In fact the maps will be
> displayed stretched always. I wasn't aware of that.
I think this is hardware specific...
$ ./scale
Xserver screen resolution: x:100.036923 dpi y:100.036923 dpi
Map parameters:
True map size: we_meters: 372.437764 ns_meters: 344.119786
Pixel numbers used in screen: ns: 494.321745 we:535.000000
Map rows: 865 map cols: 958
Map height in meter: 0.125511
Map width in meter: 0.135840
y-scale: 1:2741.741697
x-scale: 1:2741.741697
[Ahh, but they are the same on my hardware...]
I recall reading the the DisplayHeightMM type routines might not return
true measurements. That is, these routines are dependent on the
hardware reporting which apparently isn't always reliable.
> It would be great to have the map scale displayed in top line of
> GRASS monitor (of course get the sockets fully working is highest
> priority).
The server would have to query the region settings, like you did. And,
it would need a hook to recalculate when the window is resized.
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
