[GRASS5] One step at a time. erase at start-up
Helena hmitaso at unity.ncsu.edu
Sun Feb 18 15:15:50 EST 2001
Rich Shepard wrote:
>   When I try to enter location and mapset names, I have no erase capability
> (i.e., neither the delete nor the backspace keys work). Is this normal?
for as far as I have been using GRASS (good 10 years) there was
no erase capability - you have to go back and rewrite. That is why a new
start-up GUI is highly desirable. I don't know the answer to the d.mon problem.
Helena
>   When I finally get to the command prompt I try starting a monitor, and
> this is what I get:
> GRASS:/mnt/usr4/coeur-rochester/data > d.mon start=x0
> Sorry, </usr/local/grass5/dev/fifo.1a> not available
> Have GRASS adminstrator check etc/monitorcap file
> Can't stat /usr/local/grass5/dev/fifo.1a
> Problem selecting x0. Will try once more
>   When I list the monitors, x0 through x6 are shown to be available. So,
> what have I left off here?
>   BTW, this is with beta-11.2.
> Thanks,
> Rich
> Dr. Richard B. Shepard, President
>                        Applied Ecosystem Services, Inc. (TM)
>               Making environmentally-responsible mining happen. (SM)
>             2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
>  + 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard at appl-ecosys.com
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
