[GRASS5] Re: r.thin
Federico Ponchio ponchio at ruffini.dm.unipi.it
Fri Feb 16 20:14:59 EST 2001
Helena,
	you are right, it wasn't my intention to replace the code, but to
give another option. I sent the code to Markus to test it, with some map.
I promise I will merge the two pieces of code.
	Federico
On Fri, 16 Feb 2001, Helena wrote:
> Federico, Markus,
> I am not sure whether I understand correctly what you have done,
> but I would not rely on keeping the raster in RAM, raster files that people
> may want to process may be huge and complex and they won't compress
> that well and you will end up with users complaining that they cannot
> use r.thin because they don't have enough RAM - it is much easier to find extra
> disks space
> than extending your RAM. So I suggest that writing a compressed
> file to disk should be there even if it is slower, at least as an option.
> Helena
> > Hi Markus,
> >         probably i just forgotted to attach it. I resend it.
> > About the tiles i do not know, it depends on how its implemented.
> > I'll have a look around for some ideas.
> >         Federico
> > > Hi Federico,
> > > On Sun, Feb 11, 2001 at 10:00:05PM +0100, Federico Ponchio wrote:
> > > > Hello,
> > > >     i whish to submit to you a small improvement i did to r.thin.
> > > > This, of course, not in case someone else already did it, i have beta10,
> > > > and still had no time to learn CVS...
> > > ... currently r.thin is untouched.
> > > > I had to extract a vecor file from level curves rasterized, for a engeneer
> > > > friend.
> > > > Im quite new to this kind of thing so i used r.thin and then r.line.
> > > > Was this the best conduct?
> > > Yes, this is the way.
> > > > Unfortunately r.thin uses a temporary work file which holds uncompressed
> > > > temporary data, and this file in my case was 1GB or more (i had no more
> > > > disk left), causing sluggishly swaping (im being heufemistic).
> > > > I just rewrote a couple of rutine to use zlib and store *compressed*
> > > > temporary file, it seems to work good. I send you the cmd directory.
> > > Mhh, it was not attached.
> > > > Plus: No disk usage, all stays in ram (6Mb in my case).
> > > > Contra: Some file my not compress that well and Ram could be insufficent
> > > > to deal with (not that likely on modern computers), slower on smal
> > > > files (those which would fit into memory uncompressed, do not know how
> > > > much, would need to test but i have no time to do so).
> > > > I have only 1 suitable raster data to test with... will you test it a bit
> > > > more (notice i didn't touch the algorithm, only worked with memory
> > > > management)?
> > > Yes, I could test it.
> > > > You may replace the old module or merge the two ones... (i do not think
> > > > its worth the effort to merge, but can't be sure without some comparison
> > > > testing).
> > > >                             Federico.
> > > > P.S. I think theres extra room for improving but sorry, i lack the time.
> > > Eric Miller was thinking about having tiled raster format in GRASS.
> > > Probably that would fix your problem (I am no expert here). Probably
> > > you talk to him through the GRASS 5 mailing list? Then the others
> > > can throw in their ideas as well.
> > > Talk to you soon,
> > >  Markus
> >    cmd.tgz    Type: APPLICATION/x-gzip
> >           Encoding: BASE64
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
