[GRASS5] sockets and Solaris
Bob Covill
bcovill at tekmap.ns.ca
Fri Feb 16 08:59:15 EST 2001
"Eric G . Miller" wrote:
> On Thu, Feb 15, 2001 at 04:37:49PM -0400, Bob Covill wrote:
> > Eric,
> > I have been trying to build the latest grass release under Solaris (7)
> > today. One of the problems that I have encountered is in "unix_socks.c"
> > in the gis lib. It fails at line 123 because it cannot find a definition
> > for PF_LOCAL. I have checked sys/socket.h, and for some reason it is not
> > defined there.
> > Any idea where I would find an upgrade to include PF_LOCAL?
> I should've know better than using PF_LOCAL (Posix).
> s/PF_LOCAL/AF_LOCAL/ and if that doesn't work s/AF_LOCAL/AF_UNIX/.
> I'll change it to AF_LOCAL in CVS...
> FYI: I found the definition in /usr/include/bits/socket.h (which is
> included by /usr/include/sys/socket.h). It defines PF_UNIX, AF_LOCAL,
> and AF_UNIX as synonyms for PF_LOCAL (which is defined as 1 here).
> Eric G. Miller <egm2 at jps.net>
Eric,
Just to be difficult, Solaris does not define AF_LOCAL either. I have attached my
socket.h file to show how things are defined on my Solaris system. It does not
look for a bits/socket.h file as on other systems (linux), everything seems to be
defined in this one file from sys/socket.h.
Is AF_UNIX and PF_UNIX the same as AF_LOCAL? Would it be a legal fix to replace
AF_LOCAL with AF_UNIX? I am completely in the dark when it comes to sockets.
Thanks in advance for any assistance.
Bob Covill
Tekmap Consulting
P.O. Box 2016
Fall River, N.S.
B2T 1K6
Canada
E-Mail: bcovill at tekmap.ns.ca
Phone: 902-860-1496
Fax: 902-860-1498
/* Copyright (c) 1984, 1986, 1987, 1988, 1989 AT&T */
/* All Rights Reserved */
/* THIS IS UNPUBLISHED PROPRIETARY SOURCE CODE OF AT&T */
/* The copyright notice above does not evidence any */
/* actual or intended publication of such source code. */
#ifndef _SYS_SOCKET_H
#define _SYS_SOCKET_H
#pragma ident "@(#)socket.h 1.48 98/06/19 SMI" /* SVr4.0 1.10 */
* PROPRIETARY NOTICE (Combined)
* This source code is unpublished proprietary information
* constituting, or derived under license from AT&T's UNIX(r) System V.
* In addition, portions of such source code were derived from Berkeley
* 4.3 BSD under license from the Regents of the University of
* California.
* Copyright Notice
* Notice of copyright on this source code product does not indicate
* publication.
* (c) 1986,1987,1988,1989 Sun Microsystems, Inc
* (c) 1983,1984,1985,1986,1987,1988,1989 AT&T.
* All rights reserved.
#include <sys/types.h>
#include <sys/uio.h>
#include <sys/feature_tests.h>
#ifndef _KERNEL
#if !defined(_XPG4_2) || defined(__EXTENSIONS__)
#include <sys/netconfig.h>
#endif /* !defined(_XPG4_2) || defined(__EXTENSIONS__) */
#endif /* !_KERNEL */
#ifdef __cplusplus
extern "C" {
#endif
#ifndef _SA_FAMILY_T
#define _SA_FAMILY_T
typedef uint16_t sa_family_t;
#endif
#ifndef _SOCKLEN_T
#define _SOCKLEN_T
#if defined(_XPG4_2) && !defined(_XPG5) && !defined(_LP64)
typedef size_t socklen_t;
#else
typedef uint32_t socklen_t;
#endif /* defined(_XPG4_2) && !defined(_XPG5) && !defined(_LP64) */
typedef socklen_t *Psocklen_t;
#else
typedef void *Psocklen_t;
#endif /* defined(_XPG4_2) */
#endif /* _SOCKLEN_T */
* Definitions related to sockets: types, address families, options.
#ifndef NC_TPI_CLTS
#define NC_TPI_CLTS 1 /* must agree with netconfig.h */
#define NC_TPI_COTS 2 /* must agree with netconfig.h */
#define NC_TPI_COTS_ORD 3 /* must agree with netconfig.h */
#define NC_TPI_RAW 4 /* must agree with netconfig.h */
#endif /* !NC_TPI_CLTS */
* Types
#define SOCK_STREAM NC_TPI_COTS /* stream socket */
#define SOCK_DGRAM NC_TPI_CLTS /* datagram socket */
#define SOCK_RAW NC_TPI_RAW /* raw-protocol interface */
#else
#define SOCK_STREAM 2 /* stream socket */
#define SOCK_DGRAM 1 /* datagram socket */
#define SOCK_RAW 4 /* raw-protocol interface */
#define SOCK_RDM 5 /* reliably-delivered message */
#define SOCK_SEQPACKET 6 /* sequenced packet stream */
* Option flags per-socket.
#define SO_DEBUG 0x0001 /* turn on debugging info recording */
#define SO_ACCEPTCONN 0x0002 /* socket has had listen() */
#define SO_REUSEADDR 0x0004 /* allow local address reuse */
#define SO_KEEPALIVE 0x0008 /* keep connections alive */
#define SO_DONTROUTE 0x0010 /* just use interface addresses */
#define SO_BROADCAST 0x0020 /* permit sending of broadcast msgs */
#define SO_USELOOPBACK 0x0040 /* bypass hardware when possible */
#define SO_LINGER 0x0080 /* linger on close if data present */
#define SO_OOBINLINE 0x0100 /* leave received OOB data in line */
#define SO_DGRAM_ERRIND 0x0200 /* Application wants delayed error */
* N.B.: The following definition is present only for compatibility
* with release 3.0. It will disappear in later releases.
#define SO_DONTLINGER (~SO_LINGER) /* ~SO_LINGER */
* Additional options, not kept in so_options.
#define SO_SNDBUF 0x1001 /* send buffer size */
#define SO_RCVBUF 0x1002 /* receive buffer size */
#define SO_SNDLOWAT 0x1003 /* send low-water mark */
#define SO_RCVLOWAT 0x1004 /* receive low-water mark */
#define SO_SNDTIMEO 0x1005 /* send timeout */
#define SO_RCVTIMEO 0x1006 /* receive timeout */
#define SO_ERROR 0x1007 /* get error status and clear */
#define SO_TYPE 0x1008 /* get socket type */
#define SO_PROTOTYPE 0x1009 /* get/set protocol type */
/* "Socket"-level control message types: */
#define SCM_RIGHTS 0x1010 /* access rights (array of int) */
#define SO_STATE 0x2000 /* Internal: get so_state */
#ifdef _KERNEL
#define SO_SRCADDR 0x2001 /* Internal: AF_UNIX source address */
#define SO_FILEP 0x2002 /* Internal: AF_UNIX file pointer */
#define SO_UNIX_CLOSE 0x2003 /* Internal: AF_UNIX peer closed */
#endif /* _KERNEL */
* Structure used for manipulating linger option.
struct linger {
int l_onoff; /* option on/off */
int l_linger; /* linger time */
* Level number for (get/set)sockopt() to apply to socket itself.
#define SOL_SOCKET 0xffff /* options for socket level */
* Address families.
#define AF_UNSPEC 0 /* unspecified */
#define AF_UNIX 1 /* local to host (pipes, portals) */
#define AF_INET 2 /* internetwork: UDP, TCP, etc. */
#define AF_IMPLINK 3 /* arpanet imp addresses */
#define AF_PUP 4 /* pup protocols: e.g. BSP */
#define AF_CHAOS 5 /* mit CHAOS protocols */
#define AF_NS 6 /* XEROX NS protocols */
#define AF_NBS 7 /* nbs protocols */
#define AF_ECMA 8 /* european computer manufacturers */
#define AF_DATAKIT 9 /* datakit protocols */
#define AF_CCITT 10 /* CCITT protocols, X.25 etc */
#define AF_SNA 11 /* IBM SNA */
#define AF_DECnet 12 /* DECnet */
#define AF_DLI 13 /* Direct data link interface */
#define AF_LAT 14 /* LAT */
#define AF_HYLINK 15 /* NSC Hyperchannel */
#define AF_APPLETALK 16 /* Apple Talk */
#define AF_NIT 17 /* Network Interface Tap */
#define AF_802 18 /* IEEE 802.2, also ISO 8802 */
#define AF_OSI 19 /* umbrella for all families used */
#define AF_X25 20 /* CCITT X.25 in particular */
#define AF_OSINET 21 /* AFI = 47, IDI = 4 */
#define AF_GOSIP 22 /* U.S. Government OSI */
#define AF_IPX 23 /* Novell Internet Protocol */
#define AF_ROUTE 24 /* Internal Routing Protocol */
#define AF_LINK 25 /* Link-layer interface */
#define AF_MAX 25
* Structure used by kernel to store most
* addresses.
struct sockaddr {
sa_family_t sa_family; /* address family */
char sa_data[14]; /* up to 14 bytes of direct address */
* Protocol families, same as address families for now.
#define PF_UNSPEC AF_UNSPEC
#define PF_UNIX AF_UNIX
#define PF_INET AF_INET
#define PF_IMPLINK AF_IMPLINK
#define PF_PUP AF_PUP
#define PF_CHAOS AF_CHAOS
#define PF_NS AF_NS
#define PF_NBS AF_NBS
#define PF_ECMA AF_ECMA
#define PF_DATAKIT AF_DATAKIT
#define PF_CCITT AF_CCITT
#define PF_SNA AF_SNA
#define PF_DECnet AF_DECnet
#define PF_DLI AF_DLI
#define PF_LAT AF_LAT
#define PF_HYLINK AF_HYLINK
#define PF_APPLETALK AF_APPLETALK
#define PF_NIT AF_NIT
#define PF_802 AF_802
#define PF_OSI AF_OSI
#define PF_X25 AF_X25
#define PF_OSINET AF_OSINET
#define PF_GOSIP AF_GOSIP
#define PF_IPX AF_IPX
#define PF_ROUTE AF_ROUTE
#define PF_LINK AF_LINK
#define PF_MAX AF_MAX
* Maximum queue length specifiable by listen.
#define SOMAXCONN 5
* Message header for recvmsg and sendmsg calls.
struct msghdr {
void *msg_name; /* optional address */
socklen_t msg_namelen; /* size of address */
struct iovec *msg_iov; /* scatter/gather array */
int msg_iovlen; /* # elements in msg_iov */
#if defined(_XPG4_2) || defined(_KERNEL)
void *msg_control; /* ancillary data */
socklen_t msg_controllen; /* ancillary data buffer len */
int msg_flags; /* flags on received message */
#else
caddr_t msg_accrights; /* access rights sent/received */
int msg_accrightslen;
#endif /* defined(_XPG4_2) || defined(_KERNEL) */
#if defined(_KERNEL)
* N.B.: we assume that omsghdr and nmsghdr are isomorphic, with
* the sole exception that nmsghdr has the additional msg_flags
* field at the end.
struct omsghdr {
#define nmsghdr msghdr
#if defined(_SYSCALL32)
struct omsghdr32 {
caddr32_t msg_name; /* optional address */
uint32_t msg_namelen; /* size of address */
caddr32_t msg_iov; /* scatter/gather array */
int32_t msg_iovlen; /* # elements in msg_iov */
caddr32_t msg_accrights; /* access rights sent/received */
uint32_t msg_accrightslen;
struct msghdr32 {
caddr32_t msg_control; /* ancillary data */
uint32_t msg_controllen; /* ancillary data buffer len */
int32_t msg_flags; /* flags on received message */
#define nmsghdr32 msghdr32
#endif /* _SYSCALL32 */
#define MSG_OOB 0x1 /* process out-of-band data */
#define MSG_PEEK 0x2 /* peek at incoming message */
#define MSG_DONTROUTE 0x4 /* send without using routing tables */
/* Added for XPGv2 compliance */
#define MSG_EOR 0x8 /* Terminates a record */
#define MSG_CTRUNC 0x10 /* Control data truncated */
#define MSG_TRUNC 0x20 /* Normal data truncated */
#define MSG_WAITALL 0x40 /* Wait for complete recv or error */
/* End of XPGv2 compliance */
#define MSG_DONTWAIT 0x80 /* Don't block for this recv */
#define MSG_XPG4_2 0x8000 /* Private: XPG4.2 flag */
#define MSG_MAXIOVLEN 16
#define SHUT_RD 0
#define SHUT_WR 1
#define SHUT_RDWR 2
struct cmsghdr {
socklen_t cmsg_len; /* data byte count, including hdr */
int cmsg_level; /* originating protocol */
int cmsg_type; /* protocol-specific type */
#if defined(__sparc)
/* To maintain backward compatibility, alignment needs to be 8 on sparc. */
#define _CMSG_HDR_ALIGNMENT 8
#else
/* for __i386 (and other future architectures) */
#define _CMSG_HDR_ALIGNMENT 4
#endif /* defined(__sparc) */
* The cmsg headers (and macros dealing with them) were made available as
* part of UNIX95 and hence need to be protected with a _XPG4_2 define.
#define _CMSG_DATA_ALIGNMENT (sizeof (int))
#define _CMSG_HDR_ALIGN(x) (((uintptr_t)(x) + _CMSG_HDR_ALIGNMENT - 1) & \
~(_CMSG_HDR_ALIGNMENT - 1))
#define _CMSG_DATA_ALIGN(x) (((uintptr_t)(x) + _CMSG_DATA_ALIGNMENT - 1) & \
~(_CMSG_DATA_ALIGNMENT - 1))
#define CMSG_DATA(c) \
((unsigned char *)_CMSG_DATA_ALIGN((struct cmsghdr *)c + 1))
#define CMSG_FIRSTHDR(m) ((struct cmsghdr *)((m)->msg_control))
#define CMSG_NXTHDR(m, c) \
((((uintptr_t) \
(_CMSG_HDR_ALIGN((char *)c + ((struct cmsghdr *)c)->cmsg_len)) + \
sizeof (struct cmsghdr)) > \
(((uintptr_t)((struct msghdr *)(m))->msg_control) + \
((uintptr_t)((struct msghdr *)(m))->msg_controllen)) ? \
((struct cmsghdr *)0) : \
((struct cmsghdr *)(_CMSG_HDR_ALIGN((char *)c) + \
((struct cmsghdr *)c)->cmsg_len))))
#endif /* _XPG4_2 */
#ifdef _XPG4_2
#ifdef __PRAGMA_REDEFINE_EXTNAME
#pragma redefine_extname bind __xnet_bind
#pragma redefine_extname connect __xnet_connect
#pragma redefine_extname recvmsg __xnet_recvmsg
#pragma redefine_extname sendmsg __xnet_sendmsg
#pragma redefine_extname sendto __xnet_sendto
#pragma redefine_extname socket __xnet_socket
#pragma redefine_extname socketpair __xnet_socketpair
#pragma redefine_extname getsockopt __xnet_getsockopt
#else /* __PRAGMA_REDEFINE_EXTNAME */
#define bind __xnet_bind
#define connect __xnet_connect
#define recvmsg __xnet_recvmsg
#define sendmsg __xnet_sendmsg
#define sendto __xnet_sendto
#define socket __xnet_socket
#define socketpair __xnet_socketpair
#define getsockopt __xnet_getsockopt
#endif /* __PRAGMA_REDEFINE_EXTNAME */
#pragma redefine_extname listen __xnet_listen
#define listen __xnet_listen
#endif /* (_XPG4_2) && !defined(_XPG5) */
#ifndef _KERNEL
#ifdef __STDC__
extern int accept(int, struct sockaddr *, Psocklen_t);
extern int bind(int, const struct sockaddr *, socklen_t);
extern int connect(int, const struct sockaddr *, socklen_t);
extern int getpeername(int, struct sockaddr *, Psocklen_t);
extern int getsockname(int, struct sockaddr *, Psocklen_t);
extern int getsockopt(int, int, int, void *, Psocklen_t);
extern int listen(int, int); /* XXX - fixme??? where do I go */
extern int socketpair(int, int, int, int *);
extern ssize_t recv(int, void *, size_t, int);
extern ssize_t recvfrom(int, void *, size_t, int, struct sockaddr *,
Psocklen_t);
extern ssize_t recvmsg(int, struct msghdr *, int);
extern ssize_t send(int, const void *, size_t, int);
extern ssize_t sendmsg(int, const struct msghdr *, int);
extern ssize_t sendto(int, const void *, size_t, int, const struct sockaddr *,
socklen_t);
extern int setsockopt(int, int, int, const void *, socklen_t);
extern int shutdown(int, int);
extern int socket(int, int, int);
#else /* __STDC__ */
extern int accept();
extern int bind();
extern int connect();
extern int getpeername();
extern int getsockname();
extern int getsockopt();
extern int listen();
extern int recv();
extern int recvfrom();
extern int send();
extern int sendto();
extern int setsockopt();
extern int socket();
extern int recvmsg();
extern int sendmsg();
extern int shutdown();
extern int socketpair();
#endif /* __STDC__ */
#ifdef __cplusplus
#endif
#endif /* _SYS_SOCKET_H */
Type: text/x-vcard
Desc: Card for Bob Covill
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20010216/77520b0b/bcovill.vcf
