[GRASS5] Grass5 on Solaris
Bob Covill
bcovill at tekmap.ns.ca
Fri Feb 16 08:16:34 EST 2001
Markus Neteler wrote:
> On Thu, Feb 15, 2001 at 06:29:54PM -0800, Eric G . Miller wrote:
> > On Thu, Feb 15, 2001 at 01:44:01PM -0400, Bob Covill wrote:
> > > Markus,
> > > You were close. It appears that flate.c was using the wrong config.h
> > > header. It was reading one from /usr/local/include, and therefore not
> > > getting any defines. If I manaully add the define HAVE_ZLIB_H to
> > > flate.c or add the full path to config.h it compiles cleanly.
> > What the heck puts a config.h in /usr/local/include ? I'd think that
> > would break a lot of software builds as config.h is the de facto
> > standard name for defining "configure" output.
> > > The problem should be solvable by ensuring that the first "-I" flag
> > > looks in grass/src/include instead of picking other config.h files.
> > Yes, it should probably always be -I. -I$(SRC)/src/include <whatever>.
> This I have seen this idea in other projects, too.
> Where to add -I.? In make.mid / CFLAGS=
> Markus
Markus & Eric,
I changed the order of EXTRA_CFLAGS and INCLUDE_DIR on the CFLAGS line of
make.mid in generic. This seems to have solved the problem of accidentally
picking up other config.h files (which apparaently should not be there in the
first place).
I have not compiled the whole thing yet so I do not know if it will have an
adverse affect down the road.
Bob Covill
Tekmap Consulting
P.O. Box 2016
Fall River, N.S.
B2T 1K6
Canada
E-Mail: bcovill at tekmap.ns.ca
Phone: 902-860-1496
Fax: 902-860-1498
Type: text/x-vcard
Desc: Card for Bob Covill
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20010216/7760e68d/bcovill.vcf
