[GRASS5] v.reclass.pg
sixote alin sixote at yahoo.com
Thu Feb 15 19:37:10 EST 2001
I think the problem is that sql with distinct clause
differs. I would try select distinct on grass_id
grass_id from .. so on. syntacsys changed in postgres
7.0 with this command.
--alex
--- mlennert at club.worldonline.be wrote:
> Trying to run v.reclass.pg on the command line with
> v.reclass.pg -s sql=recl.sql input=world2
> output=test type=area
> and recl.sql containing a simple statement like:
> select distinct grass_id
> from categories
> where valeur > 55
> I get the following error message and a segmentation
> fault :
> PQgetvalue: ERROR! field number 1 is out of range
> 0..0
> Can someone tell me what this means ?
> Moritz
> If you want to unsubscribe from GRASS Development
> Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
__________________________________________________
Do You Yahoo!?
Get personalized email addresses from Yahoo! Mail - only $35
a year!  http://personal.mail.yahoo.com/
If you want to unsubscribe from GRASS Development Team mailing list write to:
