[GRASS5] grass5install.sh error on mac os x
Jeshua Lacock
jeshua at SierraMaps.com
Thu Feb 15 16:45:31 EST 2001
>On Wed, Feb 14, 2001 at 06:57:11PM -0800, Jeshua Lacock wrote:
> > >On Wed, Feb 14, 2001 at 07:39:23AM -0600, andy agena wrote:
> > > > Hello all:
> > > > I received the error below after cat'ing Jeshua's binary pieces. The
> > > > installer didn't recognize the cat'ed package as a .tar.gz,
>when I added
> > > > the .tar.gz when cat'ing. Then I tried cat'ing to a file named
> > > > 'grass5.0beta11_Darwin_bin' and tar'ing and gz'ing it. This
>solved the
> > > > installer's problem with .tar.gz. Below is the output after
>running the
> > > > install script.
> > > > Thanks,
> > > > Andy Agena
> > >Jeshua,
> > >didn't you split the tar.gz package? If not, how to make one package
> > >from it? Obviously the cat is wrong.
> > > Markus
> > Hi Markus,
> > Yes, the package was split. And per your suggestions on how to split
> > segments you instructed to join using cat.
> > Here's what you said (private correspondence) on Tue, 14 Nov 2000
> > 14:02:05 +0000:
> > >Yes, of course:
> > > split - split a file into pieces
> > >Split into 5MB packages:
> > >split --bytes=5m bigfile.tar.gz prefix=grass5_macosX_bin.
> > >add the dot!
> > >the numbering is .aa .ab. ac etc
> > >To put them together later use
> > >cat grass5_macosX_bin.aa grass5_macosX_bin.ab > bigfile.tar.gz
> > I myself have never joined a gzip, only split them. I notice you
> > have published the segments, perhaps you can join the segments and
> > post it??? BTW: if you don't use cat, what do you use?
>Hi all,
>I have no idea about this. Currently the new MacOS-GRASS seems to be
>corrupted.
>Even "file" cannot detect the format. If Jeshua has no time to package
>it again, could you, Andy, compile and package it?
>Or, Jeshua, maybe you uploaded in ASCII instead of BIN to your server?
>Or my "wget" didn't get it properly?
>Sorry for no better news,
> Markus
Hello,
Oh my! I did upload it as ASCII. I will upload it again as binaries
right now...
For some reason I was thinking ASCII was the correct transfer mode...
Sorry,
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
