[GRASS5] Grass5 on Solaris
Bob Covill
bcovill at tekmap.ns.ca
Thu Feb 15 10:58:58 EST 2001
Markus Neteler wrote:
> On Thu, Feb 15, 2001 at 11:32:06AM -0400, Bob Covill wrote:
> > Hello,
> > I am trying to build the latest GRASS on my Solaris machine. The version
> > is up to date from the CVS yesterday (feb. 14).
> > The problem I am having is the GIS lib is not getting built, which is of
> > course rather important. The GIS lib is failing with file flate.c at
> > line 120. The comments in the file indicate that this will fail if ZLIB
> > is not installed. The libz is installed in /usr/local/bin.
> > Any thoughts on what I am doing wrong? It sucessfully built on Linux
> > without problem.
> > Bob Covill
> Bob,
> did you try to specify the path?
> configure --with-zlib-includes=DIR --with-zlib-libs=DIR
> This should help.
> Markus
Markus,
I have tried specifying the zlib and zinclude paths with configure with the same
result. Configure has no trouble with zlib. The error generated is " 'NULL'
undeclared (first use in function)". Where should it be seeing the definition of
NULL?
Bob Covill
Tekmap Consulting
P.O. Box 2016
Fall River, N.S.
B2T 1K6
Canada
E-Mail: bcovill at tekmap.ns.ca
Phone: 902-860-1496
Fax: 902-860-1498
Type: text/x-vcard
Desc: Card for Bob Covill
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20010215/7b00bdcd/bcovill.vcf
