[GRASS5] Grass5 on Solaris
Markus Neteler
neteler at geog.uni-hannover.de
Thu Feb 15 11:06:52 EST 2001
On Thu, Feb 15, 2001 at 11:32:06AM -0400, Bob Covill wrote:
> Hello,
> I am trying to build the latest GRASS on my Solaris machine. The version
> is up to date from the CVS yesterday (feb. 14).
> The problem I am having is the GIS lib is not getting built, which is of
> course rather important. The GIS lib is failing with file flate.c at
> line 120. The comments in the file indicate that this will fail if ZLIB
> is not installed. The libz is installed in /usr/local/bin.
> Any thoughts on what I am doing wrong? It sucessfully built on Linux
> without problem.
> Bob Covill
Bob,
did you try to specify the path?
configure --with-zlib-includes=DIR --with-zlib-libs=DIR
This should help.
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
