[GRASS5] v.reclass.pg
mlennert at club.worldonline.be mlennert at club.worldonline.be
Thu Feb 15 06:58:28 EST 2001
Trying to run v.reclass.pg on the command line with
v.reclass.pg -s sql=recl.sql input=world2 output=test type=area
and recl.sql containing a simple statement like:
select distinct grass_id
from categories
where valeur > 55
I get the following error message and a segmentation fault :
PQgetvalue: ERROR! field number 1 is out of range 0..0
Can someone tell me what this means ?
Moritz
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
