[GRASS5] grass5install.sh error on mac os x
Jeshua Lacock
jeshua at SierraMaps.com
Wed Feb 14 21:57:11 EST 2001
>On Wed, Feb 14, 2001 at 07:39:23AM -0600, andy agena wrote:
> > Hello all:
> > I received the error below after cat'ing Jeshua's binary pieces. The
> > installer didn't recognize the cat'ed package as a .tar.gz, when I added
> > the .tar.gz when cat'ing. Then I tried cat'ing to a file named
> > 'grass5.0beta11_Darwin_bin' and tar'ing and gz'ing it. This solved the
> > installer's problem with .tar.gz. Below is the output after running the
> > install script.
> > Thanks,
> > Andy Agena
>Jeshua,
>didn't you split the tar.gz package? If not, how to make one package
>from it? Obviously the cat is wrong.
> Markus
Hi Markus,
Yes, the package was split. And per your suggestions on how to split
segments you instructed to join using cat.
Here's what you said (private correspondence) on Tue, 14 Nov 2000
14:02:05 +0000:
>Yes, of course:
> split - split a file into pieces
>Split into 5MB packages:
>split --bytes=5m bigfile.tar.gz prefix=grass5_macosX_bin.
>add the dot!
>the numbering is .aa .ab. ac etc
>To put them together later use
>cat grass5_macosX_bin.aa grass5_macosX_bin.ab > bigfile.tar.gz
I myself have never joined a gzip, only split them. I notice you
have published the segments, perhaps you can join the segments and
post it??? BTW: if you don't use cat, what do you use?
Thanks,
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
