[GRASS5] Re: [GRASS-bugs] nviz2.2
Eric G . Miller
egm2 at jps.net
Mon Feb 12 14:54:38 EST 2001
On Mon, Feb 12, 2001 at 12:45:00PM +0000, Markus Neteler wrote:
> > GRASS:~ > nviz2.2
> > BUG IN DYNAMIC LINKER ld.so: dl-version.c: 210: _dl_check_map_versions: Assertion `needed != ((void *)0)' failed!
> > child process exited abnormally
> > while executing
> > "exec /usr/local/grass5/etc/nviz2.2/NVWISH2.2 -f /usr/local/grass5/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ >&@stdout"
> > ("eval" body line 1)
> > invoked from within
> > "eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f $env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script $CMD -name NVIZ >&@stdout
> > (file "/usr/local/grass5/bin/nviz2.2" line 92)
> > name: Uwe Danzeglocke
> currently there is above problem with the GRASS 5b11 Linux binaries
> on some platforms. I have no idea how to overcome it. There must be some
> library version conflict. On my platform (even Suse), it works well.
> Comments would be appreciated,
I've seen this bug reported elsewhere, and I don't think there's much we
can do about it (it actually is a glibc or ld bug, I think). Suggest
persons encountering this problem compile from source.
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
