[GRASS5] G_sock_*, XDRIVER, and other fun...
Eric G . Miller
egm2 at jps.net
Mon Feb 12 14:59:58 EST 2001
On Mon, Feb 12, 2001 at 11:48:41AM +0000, Markus Neteler wrote:
> Hi Eric,
> here my report on XDRIVER/sockets:
> o it works o.k.! And, hey, you can simply click-off the monitor...
> This is definitly a useful improvement.
> o the monitor comes up much faster
> o the refresh problem with hidden monitor is still there (KDE2,
> you will know it).
I'm still trying to figure out how to get the XDRIVER to handle 'Expose'
events properly. Unfortunately, I know little about X programming, and
am unsure what the XDRIVER would use to repaint the screen (if the
server won't do it with backing-store). Note: I'm running KDE2.1beta
and this problem doesn't exist here (with the changes to XF86Config to
always do backing store).
> Small idea to improve:
> If you click-off a monitor and run d.rast (or whatever) later, you get:
> d.rast tk25
> Socket is already in use or not accepting connections.
> This message might be extended: "Run d.mon to start new monitor.".
> A problem is, that the message doesn't time-out. Means, you need to Ctrl-C
> it away (funny: you have to hit return, before Ctrl-C is accepted).
> Could you use G_fatal_error() for this message?
Yea, I'll try to clean up some of the reporting/d.mon stuff. My first
goal was just to get it working ;)
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
