[GRASS5] zlib
B. Byars Bruce_Byars at baylor.edu
Mon Feb 12 17:38:07 EST 2001
Roger that on it being a Solaris 7 issue.  2.6 is just fine.  :-)  I've had
problems like this arise between 2.6 and 7 and will post some errors
and be experimenting with some possible fixes.  I think I'll wait on trying
Solaris 8 for a while!!!
Bruce
Markus Neteler wrote:
> On Mon, Feb 12, 2001 at 03:14:26PM -0600, B. Byars wrote:
> > Thanks Eric,
> > Yep that will get configure running (what I had to use), BUT there's
> > still big-time solaris problems.  Can;t "do-compile", setting directory
> > paths in configure are ignored, can't make binaries.  Like I say, I can
> > hard-wire things to get them to work, but configure as it is on solaris
> > 7 32-bit is awful in beta 11.
> > Shall keep you posted on fixes.
> Hi Bruce,
> currently the compile is running here on Solaris2.6 /SUN - luckily
> without problems. I will test the new XDRIVER/sockets tomorrow when
> compile is finished.
> It seems to be a solaris7 problem. It would be helpful if you post
> the errors, maybe they can be fixed easily.
> Thanks,
>  Markus
> > "Eric G . Miller" wrote:
> > > On Fri, Feb 09, 2001 at 04:18:56PM -0600, B. Byars wrote:
> > > > Solaris 7 32 bit has trouble finding zlib's located in
> > > > /usr/local/.  I've had to hard wire this to get a compile
> > > > to go.  Any quick fixes already or should I dig deeper?
> > > ./configure --help
> > > Let me know if it doesn't work (--with-zlib-<includes|libs>=[dir]).
> > > Eric G. Miller <egm2 at jps.net>
> > > If you want to unsubscribe from GRASS Development Team mailing list write to:
> > > minordomo at geog.uni-hannover.de with
> > > subject 'unsubscribe grass5'
> Markus Neteler *  University of Hannover
> Institute of Physical Geography and Landscape Ecology
> Schneiderberg 50 * D-30167 Hannover * Germany
> Tel: ++49-(0)511-762-4494  Fax: -3984
