[GRASS5] G_sock_*, XDRIVER, and other fun...
Eric G . Miller
egm2 at jps.net
Mon Feb 12 16:42:37 EST 2001
On Mon, Feb 12, 2001 at 11:48:41AM +0000, Markus Neteler wrote:
> Hi Eric,
> here my report on XDRIVER/sockets:
> o it works o.k.! And, hey, you can simply click-off the monitor...
> This is definitly a useful improvement.
> o the monitor comes up much faster
> o the refresh problem with hidden monitor is still there (KDE2,
> you will know it).
Try recompiling the XDRIVER with the little change I just made. I
turned of backingstore in X and it seems to repaint the screen correctly
now. Before, it was checking if the server responded to
DoesBackingStore() with 'Always'. However, it could also respond with a
'WhenMapped' which also means it does backingstore, but only if the
window is mapped. I changed it to check against 'NotUseful', which
means backingstore is off in the server by default. Hope it works...
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
