[GRASS5] zlib
Eric G . Miller
egm2 at jps.net
Mon Feb 12 16:37:01 EST 2001
On Mon, Feb 12, 2001 at 03:14:26PM -0600, B. Byars wrote:
> Thanks Eric,
> Yep that will get configure running (what I had to use), BUT there's
> still big-time solaris problems. Can;t "do-compile", setting directory
> paths in configure are ignored, can't make binaries. Like I say, I can
> hard-wire things to get them to work, but configure as it is on solaris
> 7 32-bit is awful in beta 11.
> Shall keep you posted on fixes.
> Bruce
I don't understand what you're saying. Even with the --with-zlib
directives, the compile still doesn't work? It should set the paths
with XDRLIB in src/CMD/head/head.in. Everything that uses libgis to do
some raster I/O, must have $(XDRLIB) on the $(CC) line. So where is it
not working?
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
