[GRASS5] zlib
B. Byars Bruce_Byars at baylor.edu
Mon Feb 12 16:14:26 EST 2001
Thanks Eric,
Yep that will get configure running (what I had to use), BUT there's
still big-time solaris problems.  Can;t "do-compile", setting directory
paths in configure are ignored, can't make binaries.  Like I say, I can
hard-wire things to get them to work, but configure as it is on solaris
7 32-bit is awful in beta 11.
Shall keep you posted on fixes.
Bruce
"Eric G . Miller" wrote:
> On Fri, Feb 09, 2001 at 04:18:56PM -0600, B. Byars wrote:
> > Solaris 7 32 bit has trouble finding zlib's located in
> > /usr/local/.  I've had to hard wire this to get a compile
> > to go.  Any quick fixes already or should I dig deeper?
> ./configure --help
> Let me know if it doesn't work (--with-zlib-<includes|libs>=[dir]).
> Eric G. Miller <egm2 at jps.net>
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
