[GRASS5] Minor problem with new socket code
Eric G . Miller
egm2 at jps.net
Mon Feb 12 01:12:26 EST 2001
On Mon, Feb 12, 2001 at 12:01:53PM +0700, Justin Hickey wrote:
> Hi Eric
> You added a #ifndef line to the file src/libes/gis/set_prior.c. However,
> on SGI using MIPSpro compilers, an error is generated since the #ifndef
> statement is missing an identifier. It wants something like
> #ifndef PRIO_PROCESS
> Is that the correct identifier to use, or should we use something else?
Sorry, dumb mistake. It should be as you have it. gcc is sometimes to
lax.
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
