[GRASS5] Uh-oh: Beta11 problem
Justin Hickey
jhickey at hpcc.nectec.or.th
Sun Feb 11 21:29:54 EST 2001
Hello Rich
Rich Shepard wrote:
> BTW, I modified grass5install.sh because I like to put applications
> such as GRASS in /opt rather than /usr/local. Worked just fine -- at
> that point. :-)
Just to let you know, you shouldn't need to edit the grass5install.sh
script. The destination and binary directories can be specified on the
command line. Below I include the usage message for grass5install.sh
Usage: sh grass5install.sh grass_binpackage.tar.gz [dest_dir] [bin_dir]
with:
grass_binpackage : name of GRASS 5 binary package
[dest_dir] - optional: FULL path name to the installation directory
(default: /usr/local/grass5/)
[bin_dir] - optional: FULL path name to the grass binary directory
(default: /usr/local/bin/)
Notes: 1) Only the grass executable file is stored here
2) If you want to change the binary directory only
then you need to specify the destination
directory as well
You may need login as root for installation.
Hope this is helpful on your next installation.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
