[GRASS5] Identify GRASS database directory
Bernhard Reiter
bernhard at intevation.de
Wed Feb 7 13:11:56 EST 2001
Hi Bruce,
if I have any directory, how can I decide if it is a GRASS database.
Especially if it contains raster data?
There must be something that all grass database directories have in
common. If it is that WIND file, it would be sufficient for
identification.
So are there WIND files in all grass database directories?
Bernhard
On Wed, Feb 07, 2001 at 12:03:29PM -0600, B. Byars wrote:
> The PERMANENT directory isn't automatically created each time
> with a new mapset. Not sure what you mean about finding out is
> a directory is a GRASS dbase directory tho'? I have a script I use to
> locate directories that looks for WIND files. Is that what you mean?
> Bruce
> Bernhard Reiter wrote:
> > Just a quick question. Is there a fast and relyable way to find out,
> > if a directory is a GRASS database directory?
> > I expect the PERMANENT mapset directory to actually be created
> > once a directory serves as a GRASS database. Is this true for all
> > cases?
> > Thanks,
> > Bernhard
> > Professional Service around Free Software (intevation.net)
> > The FreeGIS Project (freegis.org)
> > Association for a Free Informational Infrastructure (ffii.org)
> > FSF Europe (fsfeurope.org)
> > Part 1.2Type: application/pgp-signature
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20010207/6e737f44/attachment.bin
