[GRASS5] Re-release beta11
B. Byars
Bruce_Byars at baylor.edu
Tue Feb 6 15:13:27 EST 2001
I'll build Solaris Binaries. For the first time I'll try both 32-bit and
new 64-bit binaries as well. Should be no problems witht the 64-bit,
my other code compiles fine.
Bruce
Markus Neteler wrote:
> On Tue, Feb 06, 2001 at 06:02:53PM +0000, Markus Neteler wrote:
> > Hi again,
> > after discussion with Bernhard I have put back the
> > src-ball and Linux ball (this one added the missing create_fifos.sh).
> > So it shall be kept beta11.
> For those building a binary tarball:
> after compiling everything (see in src-package the file
> documents/release_rules.txt
> how to do that)
> you *must* cp manually the create_fifos.sh file:
> cp src/scripts/shells/create_fifos.sh /usr/local/grass5/dev
> ^^^^^^^^^^^^^^^^^- or wherever you
> build the scripts
> Please use the src-ball from:
> http://www.geog.uni-hannover.de/grass/grass5/source/
> grass5.0beta11_src.tar.gz
> to built the binaries. Then all balls are in sync.
> Thanks
> Markus
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
