[GRASS5] fifos not created
GRASS grass at geni.cemtlo.com
Mon Feb 5 19:13:00 EST 2001
>From neteler at geog.uni-hannover.de Mon Feb  5 19:09:14 2001
> On Mon, Feb 05, 2001 at 06:27:24PM +0900, GRASS wrote:
> > From: "Eric G . Miller" <egm2 at jps.net>
> > > On Sun, Feb 04, 2001 at 09:40:32PM -0800, Jeshua Lacock wrote:
> > > > OK, So I downloaded beta 11 and deleted the old, did a "make
> > > > distclean" and so on.  And  after it compiles I tried to start a
> > > > monitor and I get the message;
> > > >   GRASS 5.0beta11 > d.mon start=x0 Sorry,
> > > >   </usr/local/grass5/dev/fifo.1a> not available Have GRASS
> > > >   adminstrator check etc/monitorcap file Can't stat
> > > >   /usr/local/grass5/dev/fifo.1a Problem selecting x0. Will try once
> > > >   more Can't stat /usr/local/grass5/dev/fifo.1a
> > > > So I tried to inspect the fifo and found that there is no dev
> > > > directory.  Instead there is a dev script.  I tired moving the script
> > > > and running it and it creates the fifo's but then I still get the same
> > > > message.
> > > > It seems odd to me.  Beta 11 pre2 did not do this.
> > > > The only difference between this build and pre2 is one there are new
> > > > sources I downloaded today and two I am now running Xfree86 4.02 with
> > > > the Aqua patch, but I do not suspect two as being the problem.
> > > Something got puckered, not sure if it's fixed yet in CVS, but it has
> > > something to do with the README.ipc thingy.  Anyway,
> > > #! /bin/sh
> > > for i in 1 2 3 4 5 6 7 8 9 10 ; do
> > > 	mkfifo -m 0666 "fifo.""$i""a"
> > > 	mkfifo -m 0666 "fifo.""$i""b"
> > > done
> > > If you don't have mkfifo, use 'mknod -m 0666 "fifo.""$i""a" p'
> > > You could also try running ./configure --with-fifo explicitly...
> > Hi all,
> > I fixed Makefile.in and README.ipc to create "dev" directory before copying
> > anything into this directory.
> > Regards,
> > Huidae Cho
> Hi Huidae,
> shall I release an updated source code package (the binaries are not
> affected if using your patch!)?
It's not a big change, so i think it's better to announce how to fix this
install problem. Just get new Makefile.in and README.ipc and rerun make.
That's all.
Yours,
Huidae Cho
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
