[GRASS5] nviz-bug
Markus Neteler
neteler at geog.uni-hannover.de
Mon Feb 5 14:56:53 EST 2001
Helena,
me again: The hoodtest surface comes fine (white, slightly
shaded). But the states file wants "sel.80" file.
Then:
Diagnostic: invalid command name "Nviz_animation_load" -- Load procedure
for panel animation may not be defined
Diagnostic: invalid command name "Nviz_kanimator_load" -- Load procedure
for panel kanimator may not be defined
Diagnostic: invalid command name "Nviz_query_load" -- Load procedure for
panel query may not be defined
Diagnostic: invalid command name "Nviz_mkdspf_load" -- Load procedure for
panel mkdspf may not be defined
Diagnostic: invalid command name "Nviz_sdiff_load" -- Load procedure for
panel sdiff may not be defined
Obviously this is a NVIZ state from GL version?
Please put the sel.80 somewhere for further testing.
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
