[GRASS5] Options in Tcltkgrass fixed
GRASS grass at geni.cemtlo.com
Sun Feb 4 19:35:32 EST 2001
Date: Sun, 4 Feb 2001 12:29:02 +0000
From: Markus Neteler <neteler at geog.uni-hannover.de>
> Hi Justin,
> hi all
> On Wed, Jan 31, 2001 at 06:54:01PM +0700, Justin Hickey wrote:
> > Hello all
> > I fixed the tcltkgrass options list for commands so that flags (like -f
> > -m etc) will always be at the beginning of the list. For example for
> > g.manual before, the options would be
> > 	g.manual entries=d.rast -d
> > Now they are
> > 	g.manual -d entries=d.rast
> that's perfect. Thanks for the update.
> > Also, I updated the tcltkgrass module for g.manual
> > (src/tcltkgrass/module/g.manual) to reflect the options of the script as
> > opposed to the options of the command in src/general/g.manual. However,
> > somebody familiar with the script needs to fill in the browser parameter
> > properly. I had no idea what to do with that. I just put the same thing
> > as the entries parameter. Could somebody please take a look at that?
> Huidae, as you have been developing the g.manual script, could you
> please looking into this?
> > BTW, since we are using the script now, can we remove
> > src/general/g.manual to avoid confusion?
> Generally yes. Now the script will do job.
> Any objections to delete src/general/g.manual?
> Markus
Hi Markus,
I think its code is enough to reflect the browser parameter.
However, this parameter may be somewhat meaningless in the tcltkgrass or GUI.
Yours,
Huidae Cho
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
