[GRASS5] Todo
Markus Neteler neteler at geog.uni-hannover.de
Sun Feb 4 09:48:17 EST 2001
On Sun, Feb 04, 2001 at 02:42:39PM +0000, Markus Neteler wrote:
> On Sun, Feb 04, 2001 at 06:14:55AM -0700, John Huddleston wrote:
> > Grass list,
> > I checked out the code yesterday (not an update, a cvs co)
> > and it failed because it could not change directory into a TODO
> > directory.   In Unix we can have upper and lower case
> > distinctions, not so in Cygwin.  Would somebody please
> > check to see if there is a "todo" directory, if so, remove
> > the todo file?
> Hi John,
> yes, I can see the problem (bad Windows!). So I will rename
> todo/ to src.todo.
> Sorry for this inconvenience,
John,
it's done.
cvs up -dP todo src.todo
Thanks for notification,
 Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
