[GRASS5] Error in fresh compile (ipc)
Malcolm Blue
mblue at nb.sympatico.ca
Tue Jan 30 20:57:39 EST 2001
Justin,
I see in a later message that you have already updated and tested successfully.
Ignore my earlier post.
Malcolm
Malcolm Blue wrote:
> Justin,
> Re #3. See Huidae's message. He had trouble adding the renamed file to the
> src/scripts/shells directory. It looks like this has been fixed. I've just
> downloaded but haven't tested yet.
> Last night I ran into this problem and sent a message to Huidae off line, which
> he fixed almost immediately - by renaming the script file. I had already tested
> his script file and it ran correctly, it just needed to be renamed.
> Update the src/scripts/shells directory and this should be resolved.
> Malcolm
> Justin Hickey wrote:
> > Hello all
> > I just did a fresh compile on our SGI system and had three errors.
> > 1. r.cn - missing LDFLAGS in command line - fixed
> > 2. r.in.gdal - same as always
> > 3. The following messages at the end of make
> > src/scripts/shells/create_ipcs.sh - No such file or directory
> > Cannot access
> > /usr/people/jhickey/temp/grass/dist.mips-sgi-irix6.5/dev/create_ipcs.sh:
> > No idea how to fix 3. Just a report.
> > Sincerely,
> > Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
> > High Performance Computing Center
> > National Electronics and Computer Technology Center (NECTEC)
> > Bangkok, Thailand
> > People who think they know everything are very irritating to those
> > of us who do. ---Anonymous
> > Jazz and Trek Rule!!!
> > If you want to unsubscribe from GRASS Development Team mailing list write to:
> > minordomo at geog.uni-hannover.de with
> > subject 'unsubscribe grass5'
