[GRASS5] G_socks_* unix socket wrapper functions...
Malcolm Blue
mblue at nb.sympatico.ca
Tue Jan 30 20:48:03 EST 2001
IRIX looks good. It wouldn't have had the ipcs command otherwise and wouldn't
have known what to report on the queues. Some of the systems (like Linux seem to
set up queue on startup - I don't know why). Just for fun, compile grass using
IPC, start a couple of monitors and there should be 2 queues for each monitor.
Then you can tell us for sure that IRIX supports IPC, plus you can test the IPC
XDRIVER.
Cheers,
Malcolm
Eric Mitchell wrote:
> IRIX64 6.5
> IPC status from /dev/kmem as of Tue Jan 30 18:06:04 2001
> T ID KEY MODE OWNER GROUP
> Message Queues:
> Look ok?
> > > just checked some machines with "ipcs -q" to see if IPC is present:
> > > Linux: yes
> > > Solaris: yes
> > > CRAY: yes
> > HP-UX 10.2+ : yes
> > > Looks good!
> > > Markus
> | Eric B. Mitchell mailto:emitchell at altaira.com |
> | tel: (301) 809 - 3534 Altair Aerospace Corporation |
> | tel: (800) 7 - ALTAIR 4201 Northview Dr. Suite 410 |
> | fax: (301) 805 - 8122 Bowie, MD 20716 |
> ,___
> /"\ / o=\ /"""---===/
> / \_/ \__/ ---===/
> | //\ || /""TT""/ //\ || ||""\
> | // \ || || // \ || ||__/
> | //--==\ |L--/ || //--==\ || || "=,
> \____---===/
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
