[GRASS5] Configure Warning
Eric G . Miller
egm2 at jps.net
Tue Jan 30 03:48:32 EST 2001
On Mon, Jan 29, 2001 at 10:10:56PM -0800, Jeshua Lacock wrote:
[snip]
> > > It finds the Tcl/Tk libs, but reports it doesn't.
> > An unending burr in my britches... ;)
> > I'm guessing you get that with a clean slate (i.e. does removing
> > config.cache and re-running ./configure make a difference) ?
> Eric, yes, you are correct. Removing config.cache and re-running
> ./configure does not make a difference.
Figures...
> > Probably another library is needed for 'ld' in the test script that
> > is generated. Is Tk tied into the native GUI on OS X? or is it tied
> > to XFree86? Could make a difference...
> > Maybe:
> > $ ldd /usr/lib/libtk8.0.so
> > will tell you (won't work on ar archives [*.a]).
> Mmm, I have a /usr/lib/libtk8.0.a, not /usr/lib/libtk8.0.so. And I do
> not have a "ldd" program. I tired:
> $ ld /usr/lib/libtk8.0.a
No shared, just static then... ?? Still, don't know why the configure
script is failing here. I can't imagine that the library isn't being
found, so the only other thing that I've seen to be a consistent problem
with these library checks is missing dependencies to other libraries for
the configure code compile check (can your say alliteration ;). Anyway,
it's just a matter of finding out the minimal set of other libraries
needing to be referenced in order to compile a trivial piece of code
that will successfully link to libtk.
Example:
char * TkMainWindow();
int main (void)
TkMainWindow();
return 0;
Then:
$ $(CC) trivial_code.c -L/usr/X11R6/lib -lXt -ltk8.0 -ltcl8.0
Try compiling that, optionally adding -lSM -lX11 -lICE. If adding one
of these options makes it work where it didn't work before, I think I
know how to fix this problem (add $(X_PRE_LIBS) to ld_flags...).
> And it reports: "ld: no object files loaded"
ld != ldd. Confused? ld is the linker (puts the object files together
and resolves library dependencies during compilation). ldd is a program
to show shared library dependencies. Static libraries don't have
dependency info (external references are unresolved) so it doesn't work
on them...
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
