[GRASS5] G_socks_* unix socket wrapper functions...
Eric G . Miller egm2 at jps.net
Tue Jan 30 03:30:07 EST 2001
On Mon, Jan 29, 2001 at 10:31:10PM -0800, Jeshua Lacock wrote:
> On Monday, January 29, 2001, at 08:49 PM, Eric G . Miller wrote:
> > On Mon, Jan 29, 2001 at 05:54:39PM -0800, Jeshua Lacock wrote:
> > > On Monday, January 29, 2001, at 05:03 PM, Malcolm Blue wrote:
> > > > Also, are IPC message queues implemented on all of the
> > > > platforms?  It is on  UNIX's and now works on Cygwin for WinNT,
> > > > but what about other platforms, e.g..  Mac OS X?  Maybe people
> > > > using platforms that don't support IPC can respond to  this (if
> > > > no one responds can we assume that all support this?)
> > > How do I test it or find out if MacOS X supports IPC??
> > Have /usr/include/sys/ipc.h ?
> Yes.
Okay, must be there.
> > Have /usr/include/bits/ipc.h ?
> No.
Probably doesn't mean anything -- sys/ipc.h is the *real* one to look
for.
> > Run "nm /usr/lib/libc.a | grep msgget" (provided that's the path to
> > libc) will indicate if it exists in the library.
> I cannot locate a "libc.a" anywhere on my system.  I do have a libc.h,
> libc.p, libcc_dynamic.a but no libc.a.  Weird huh?
Scratching head... Obviously, it's around somewhere, apparently some
kind of different naming convention???  As long as the compiler
understands -lc ...
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
