[GRASS5] Mac OS X errors
Malcolm Blue mblue at nb.sympatico.ca
Tue Jan 30 00:20:20 EST 2001
Justin,
Yes, the change to Makefile did the trick.  After I renamed INSTALL.doc back to
INSTALL, I got the error that Justin reported with 'make install'.  When I made
the changes you suggested in Makefile, grass was (re)installed. i.e. it did not
report "`install' is up to date" and stop.
Good call.
Malcolm
Justin Hickey wrote:
> Hi Malcolm
> Malcolm Blue wrote:
> > This sounds familiar.
> > I suspect that Mac OS X is not case sensitive - like Cygwin.  I moved
> > "INSTALL" to "INSTALL.doc" and everything worked fine.
> > I forgot that I had done that!
> > Can we rename INSTALL?
> Ahh. I see. Renaming INSTALL would be one fix but this can also be fixed
> in the Makefile, which I think is the best fix. That way we avoid other
> problems like this. The fix I gave Jeshua should work. Could either you
> or Jeshua confirm this. If so, I'll add it to the Makefile.
> Thanks for the catch.
> Sincerely,
> Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
> High Performance Computing Center
> National Electronics and Computer Technology Center (NECTEC)
> Bangkok, Thailand
> People who think they know everything are very irritating to those
> of us who do.  ---Anonymous
> Jazz and Trek Rule!!!
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
