[GRASS5] Mac OS X errors
Justin Hickey
jhickey at hpcc.nectec.or.th
Mon Jan 29 23:19:00 EST 2001
Hi Malcolm
Malcolm Blue wrote:
> This sounds familiar.
> I suspect that Mac OS X is not case sensitive - like Cygwin. I moved
> "INSTALL" to "INSTALL.doc" and everything worked fine.
> I forgot that I had done that!
> Can we rename INSTALL?
Ahh. I see. Renaming INSTALL would be one fix but this can also be fixed
in the Makefile, which I think is the best fix. That way we avoid other
problems like this. The fix I gave Jeshua should work. Could either you
or Jeshua confirm this. If so, I'll add it to the Makefile.
Thanks for the catch.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
