[GRASS5] Mac OS X errors
Malcolm Blue
mblue at nb.sympatico.ca
Mon Jan 29 23:11:39 EST 2001
This sounds familiar.
I suspect that Mac OS X is not case sensitive - like Cygwin. I moved "INSTALL"
to "INSTALL.doc" and everything worked fine.
I forgot that I had done that!
Can we rename INSTALL?
Malcolm
Justin Hickey wrote:
> Hi Jeshua
> Jeshua Lacock wrote:
> > On Monday, January 29, 2001, at 05:54 PM, Justin Hickey wrote:
> > > > It says: "make: `install' is up to date." and it does nothing
> > > > other then return the command prompt. It doesn't hang or
> > > > apparently do anything.
> > > Hmmm. Is there a file in the same directory called "install"? If so
> > > please rename it and then "make install" should work. If not, I know
> > > there is a file called "install-sh", try renaming that file.
> > Justin,
> > There is not an install file, so I moved the install-sh and its the
> > same. Sorry for the headaches...
> Don't worry about the headaches, the more portable we get this the
> better.
> The only way I know for you to be getting the "make install: is already
> up to date" message is that make is finding a file called install
> somewhere. Don't worry about it, there are ways around this (I hope).
> Try putting the following in your Makefile:
> replace the line
> install:
> with the lines
> FORCE:
> install: FORCE
> and let me know if "make install" works.
> Sincerely,
> Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
> High Performance Computing Center
> National Electronics and Computer Technology Center (NECTEC)
> Bangkok, Thailand
> People who think they know everything are very irritating to those
> of us who do. ---Anonymous
> Jazz and Trek Rule!!!
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
