[GRASS5] Mac OS X errors
Jeshua Lacock jeshua at SierraMaps.com
Mon Jan 29 21:29:51 EST 2001
On Monday, January 29, 2001, at 05:54 PM, Justin Hickey wrote:
> > It says: "make: `install' is up to date." and it does nothing other
> > then return the command prompt.  It doesn't hang or apparently do
> > anything.
> Hmmm. Is there a file in the same directory called "install"? If so
> please rename it and then "make install" should work. If not, I know
> there is a file called "install-sh", try renaming that file.
Justin,
There is not an install file, so I moved the install-sh and its the same.  Sorry for the headaches...
Yours,
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
