[GRASS5] Mac OS X errors
Justin Hickey
jhickey at hpcc.nectec.or.th
Mon Jan 29 20:54:57 EST 2001
Hi Jeshua
Jeshua Lacock wrote:
> It says: "make: `install' is up to date." and it does nothing other
> then return the command prompt. It doesn't hang or apparently do
> anything.
Hmmm. Is there a file in the same directory called "install"? If so
please rename it and then "make install" should work. If not, I know
there is a file called "install-sh", try renaming that file.
> One note, I ran the make script as root and proceeded despite the
> warning. I think I am going to compile pre2 as a regular user....
Compiling as root shouldn't matter. The warning is there because in
general, user root should be used as little as possible to avoid
catastrophic errors.
I hope this helps.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
