[GRASS5] Bad Fifo! - Mac OS X
Malcolm Blue malcolmblue at yahoo.ca
Sun Jan 28 08:22:34 EST 2001
Jeshua,
Yes, that fifo.1a listing looks correct.  And the 'p'
at the start of the permissions indicated that it was
correctly created as a FIFO file.
I think that not all of the needed routines (like
d.mon  routines) got recompliled when you updated
io.c.  I also think that I should have included that
vital information in my previous email.  There are a
lot of grass routines that use the raster library
routines.
To make sure that the routines that need the libraster
updates get recompiled, you can use the README.ipc
script.  I have used this to set up the IPC
configuration, but it also has an option to return to
the normal (FIFO) configuration.  To do this, in the
grass root dir:
.README.ipc -f orig
That should force everything back to the normal
configuration.  Note that this version of README.ipc
has probably not been exhaustively tested.  Another
option is to clean up and recompile from scratch, eg.
make clean
make
This will take longer, but should get rid of any code
that's still linked to the IPC version of the raster
library routines.
Hopefully, your next message will tell us of your
success!
Malcolm
--- Jeshua Lacock <jeshua at SierraMaps.com> wrote:
> >I'm  sorry.
> >The code in src/libes/raster/   needs to be updated
> as well.  You should only
> >need to update the io.c file in that directory.
> Sorry for the extra work.
> >(This is the routine where the error message is
> generated - but both this and
> >the XDRIVER were changed together).
> >Malcolm
> >Jeshua Lacock wrote:
> >>  On Friday, January 26, 2001, at 04:34 PM,
> Malcolm Blue wrote:
> >>  > Please see the messages related to XDRIVER
> problems on the list.  These
> >>  > problems were caused by an inadvertent mix of
> FIFO and IPC messaging  in
> >>  > the grass libraries and the XDRIVER and the
> file types in the dev
> >>  > directory.
> >>  > The XDRIVER code has been reinstated, so you
> should update the
> >>  > src/display/devices/XDRIVER directory.  After
> that it should work for
> >>  > you.
> >>  Hi Malcolm,
> >  > I just updated and compiled, and I get the same
> fifo error.
> Hi again,
> I updated io.c, compiled and got the same error, so
> I updated the
> whole src/libes/raster/ directory and I still get
> the same error:
>     /usr/local/grass5/dev/fifo.1a: Operation not
> supported
> Heres a ls -la of fifo.1a:
>     prw-rw-rw-  1 jeshua  wheel  0 Jan 25 23:48
> Is it normal to be zero bytes?
> Thanks,
> Jeshua Lacock
> Cartographer/Owner
> http://SierraMaps.com
> http://3dTopoMaps.com
> Telephone: (760) 935-4481
> If you want to unsubscribe from GRASS Development
> Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
_______________________________________________________
Do You Yahoo!?
Get your free @yahoo.ca address at http://mail.yahoo.ca
If you want to unsubscribe from GRASS Development Team mailing list write to:
