[GRASS5] Bad Fifo! - Mac OS X
Jeshua Lacock
jeshua at SierraMaps.com
Sat Jan 27 19:15:15 EST 2001
>I'm sorry.
>The code in src/libes/raster/ needs to be updated as well. You should only
>need to update the io.c file in that directory. Sorry for the extra work.
>(This is the routine where the error message is generated - but both this and
>the XDRIVER were changed together).
>Malcolm
>Jeshua Lacock wrote:
>> On Friday, January 26, 2001, at 04:34 PM, Malcolm Blue wrote:
>> > Please see the messages related to XDRIVER problems on the list. These
>> > problems were caused by an inadvertent mix of FIFO and IPC messaging in
>> > the grass libraries and the XDRIVER and the file types in the dev
>> > directory.
>> > The XDRIVER code has been reinstated, so you should update the
>> > src/display/devices/XDRIVER directory. After that it should work for
>> > you.
>> Hi Malcolm,
> > I just updated and compiled, and I get the same fifo error.
Hi again,
I updated io.c, compiled and got the same error, so I updated the
whole src/libes/raster/ directory and I still get the same error:
/usr/local/grass5/dev/fifo.1a: Operation not supported
Heres a ls -la of fifo.1a:
prw-rw-rw- 1 jeshua wheel 0 Jan 25 23:48 /usr/local/grass5/dev/fifo.1a
Is it normal to be zero bytes?
Thanks,
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
