[GRASS5] r.contour crashes if step=0.5
Roger Bivand
rsb at reclus.nhh.no
Sat Jan 27 10:30:32 EST 2001
On Sat, 27 Jan 2001, Markus Neteler wrote:
> Roger,
> great!
> On Sat, Jan 27, 2001 at 02:26:32PM +0100, Roger Bivand wrote:
> > I think we need the fmod(x,y) function (K&R2: floating point remainder of
> > x/y, same sign as x; y=0 needs to be trapped, p. 251 in my edition). So:
> > dmax = (max->answer) ? atof (max->answer) : zmax - (int)zmax%(int)dstep;
> > could be
> > dmax = (max->answer) ? atof (max->answer) : dstep == 0 ?
> > G_error(***) : zmax - fmod(zmax, dstep);
> > though I haven't tried it.
> I have rewritten the other macro accordingly:
> Old:
> dmin = (min->answer) ? atof (min->answer) : (int)zmin%(int)dstep?
> zmin - (int)zmin%(int)dstep +dstep: zmin;
> New:
> dmin = (min->answer) ? atof (min->answer) : dstep == 0 ?
> G_fatal_error("This step value is not allowed.") :
> fmod(zmin,dstep) ? zmin - fmod(zmin,dstep) +dstep: zmin;
> And it seems to produce reasonable results:
> Old macro with fp-exception if min/max not specified:
> r.contour in=ph_upper out=ph_upper step=0.1 min=5.64 max=7.19
> Reading data.
> Percent complete: 100%
> FPRange of data: min = 5.647517 max = 7.195973
> Minimum level will be 5.740000
> Maximum level will be 7.190000
> Continue?(y/n) [y]
> New version:
> New:
> Reading data.
> Minimum level will be 5.700000
> Maximum level will be 7.100000
> Continue?(y/n) [y]
OK!
> New:
> Reading data.
> Continue?(y/n) [y]
Also OK!
> r.contour in=ph_upper out=ph_upper step=0.1 min=5.647 max=7.196
> Reading data.
> Minimum level will be 5.747000
> Maximum level will be 7.096000
> Continue?(y/n) [y]
> Total levels: 15 Current level:
> Finished.
This is a bit odd, though. It's being post-processed by the subsequent
code to bring the max & min within the FPRange - ideally, the levels
should be "pretty" numbers, say for a 0.1 step breaking on 0.1, 0.2, ...,
or 0.15, 0.25, .... But that's what's in the code ...
Roger
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Breiviksveien 40, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 93 93
e-mail: Roger.Bivand at nhh.no
and: Department of Geography and Regional Development, University of
Gdansk, al. Mar. J. Pilsudskiego 46, PL-81 378 Gdynia, Poland.
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
