[GRASS5] XDRIVER problems
Malcolm Blue
malcolmblue at yahoo.ca
Sat Jan 27 11:49:18 EST 2001
I have tested the configure, README.ipc and ipc.new
(SWITCHER.c and io.c) updates on cygwin and these work
well. I will test on Linux as well.
Thanks for the quick response, Huidae.
Malcolm
--- John Huddleston <jhudd at lamar.colostate.edu> wrote:
> Thank you Markus, Huidae, and Malcolm,
> From now on I will concentrate on building it.
> John Huddleston
> ----- Original Message -----
> From: "Markus Neteler"
> <neteler at geog.uni-hannover.de>
> To: <grass5 at geog.uni-hannover.de>
> Sent: Friday, January 26, 2001 11:23 AM
> Subject: Re: [GRASS5] XDRIVER problems
> <snip>
> > No, Huidae just implemented two new parameters
> into "configure":
> > --with-ipc use ipc XDriver instead
> of fifo (for Cygwin)
> > --with-fifo use fifo XDriver instead
> of ipc (default)
> > Huidae - good idea, thanks!
> > So it shouldn't bother you any more and the IPC
> code can be
> > savely developed in parallel.
> > Markus
> If you want to unsubscribe from GRASS Development
> Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
_______________________________________________________
Do You Yahoo!?
Get your free @yahoo.ca address at http://mail.yahoo.ca
If you want to unsubscribe from GRASS Development Team mailing list write to:
