[GRASS5] how to NULL in site lists?
Markus Neteler
neteler at geog.uni-hannover.de
Fri Jan 26 17:02:32 EST 2001
Hi Andreas,
> i agree with Eric and Roger that the quick fix is not advisable.
.. I am convinced :-)
>But there is another more general consideration to the NULLs in site
>lists.
>IMHO the site list format is for the storage of point data derived from
>measurements. Usually the points are irregularily spaced. The site list
>contains the spatial data (coordinates) and the attribute(s) in a sort of
>1:1 database. So if you have no value (measurement) at a given point, there
>should be no site list entry/line.
This is my current workaround (wrote a small s.cut to extract columns
from a multi-att sites list).
>The problem comes from changing the sites format from one attribute to
>several attributes. This can not be modelled adequate with a 1:1 database
>structure.
>Another approach would be to create a site list for each attribute/variable
>and to ommit the sites where no measurement/variable value is available
>(NULL attributes). I don't know if NULL values with site files are
>conceptually correct.
As you see the problems arises from multi-att site lists. An Example:
Say, you have numerous soil profiles with some parameters for each
horizont. So I save this in a 3D sites list:
x1 y1 z1 att1a att2a att3a -> soil profile 1
x1 y1 z2 att1b att2b att3b
x1 y1 z3 att1c att2c att3c
x2 y2 z1 att1d NULL(not measured) att3d -> soil profile 2
x2 y2 z2 att1e att2e att3e
It would be great to allow such a NULL (or * or whatever),
because the sites format is easy to handle.
I don't know another way how to get in such data. And in
real life it is possible, that some values might be unknown.
In my case I have 280 horizonts in 24 profiles with each 43
parameters from the geo-ecological laboratory. It wouldn't be
fun to treat every parameter as an own sites list...
If the sites would be stored in a DBMS (maybe the forthcoming
internal DMBS for the vector atts), it should be possible to
define empty fields. In 5.0 it will be to complicated.
Just my 0.02Euro
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
