[GRASS5] GRASS 5beta11pre1 - ?error in d.vect
Arne Pallentin
arne at waikato.ac.nz
Fri Jan 26 18:34:39 EST 2001
Hi all,
After Markus Neteler all ready solved one of my problems I came up with in the
beta11pre1 here is one more:
GRASS compiled and installed fine, but running d.vect from tcltk
(Display->Vector->display vector map) results in a "zombi" that I have to
kill before the tcltk interface can be stopped. Here the result of ps ax:
4870 pts/3 S 0:00 sh ./grass5
4873 pts/3 S 0:00 sh /opt/grassb11p1//grass5/etc/Init.sh
4886 pts/3 S 0:00 wish /opt/grassb11p1//grass5/bin/tcltkgrass
4901 ? R 1:10 x0 /opt/grassb11p1//grass5/dev/fifo.1a
/opt/grassb11p1//grass5/dev/fifo.1b
I hope someone understands this. If you need further info I will try to answer.
By the way, the vector I used for testing works fine in the CVS dating
08/01/2001...
Thanks everyone,
Arne
Arne Pallentin
Department of Earth Sciences
The University of Waikato
Private Bag 3105
Hamilton - New Zealand
Ph.: +64-7-838 4024 ext. 6229
Home: +64-7-856 7877
Fax. +64-7-856 0115
e-mail: arne at waikato.ac.nz
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
