[GRASS5] Mac OS X errors
David D Gray ddgray at armadce.demon.co.uk
Fri Jan 26 13:25:14 EST 2001
Markus Neteler wrote:
> On Fri, Jan 26, 2001 at 01:52:50PM +0000, David D Gray wrote:
> > Jeshua Lacock wrote:
> > > Greetings,
> > > I just compiled beta 11 on Mac OS X and here are the errors from modules tat I could not figure out (most of these errors have been posted before with previous builds):
> > > src/mapdev/v.in.shape:
> > >    shp2dig.c:25: header file 'malloc.h' not found
> > > I got this module compiled before (beta 10)  by using:
> > > Copying /System/Library/Frameworks/System.framework/Versions/B/Headers/bsd/sys/malloc.h to src/include.
> > > Now I get the errors:
> > > malloc.h:257: undefined type, found `u_short'
> > > malloc.h:258: undefined type, found `u_short'
> > > The same thing goes for these modules:
> > > v.mkgrid, v.out.shape, src.contrib/SDTS
> > Jeshua
> > I have changed the #includes to stdlib.h which is probably OK on Mac OS
> > X in v.in.shape, v.out.shape and v.mkgrid, and should #include malloc.h
> > on other systems. Hopefully they will compile OK now.
> If this fix is o.k., here is a list of other modules which might have
> the same problem (sorry, no time to fix it):
> find . -name '*.[hc]' -exec grep -l malloc.h {} \;
> ./src/include/std_incs.h
> ./src/libes/vect32_64/shapelib-1.2.8/shapefil.h
> ./src/mapdev/v.in.shape/cleanup.c
> ./src/mapdev/v.in.shape/shapefil.h
> ./src/mapdev/v.out.shape/shapefil.h
> ./src/sites/s.in.shape/cmd/shapefil.h
> ./src/sites/s.in.dbf/shapefil.h
> ./src.contrib/CERL/raster/r.hydro.CASC2D/all.h
> ./src.contrib/CERL/sites/s.surf.krig/nrutil.c
> ./src.contrib/SDTS/mapdev/v.in.sdts/att_ff_info.c
> ./src.garden/grass.postgresql/pg.in.dbf/shapefil.h
> ./src.garden/grass.postgresql/v.in.arc.pg/shapefil.h
> ./src.garden/grass.postgresql/v.in.shape.pg/cleanup.c
> ./src.garden/grass.postgresql/v.in.shape.pg/shapefil.h
> ./src.garden/grass.postgresql/v.in.shape.pg/shp2dig.c
> Markus
OK. I will look at those this evening. I think there is never any
problem with changing to stdlib.h because either it is necessary or it
#includes malloc.h anyway.
David
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
