[GRASS5] XDRIVER problems
Markus Neteler
neteler at geog.uni-hannover.de
Fri Jan 26 13:23:12 EST 2001
Hi John and all Cygnus friends,
On Fri, Jan 26, 2001 at 10:32:41AM -0700, John Huddleston wrote:
> My fault everyone,
> I had put the ipc.new source code into the system. I thought it
> had been tested in the Unix platforms. I remember seeing an
> email from Markus stating that it was faster.
John, I wasn't expecting that you would install into the main
directory but into the ipc.new/ subdirectory unless it was
tested on *all* platforms.
Never mind...
> I'll reiterate what I asked Markus offline. It would be nice
> to have a phone conversation with all parties involved.
> Email and the day or two delay can only go so far.
Very true! I still would be glad if the developers could meet
each other!
> Thanks Huidae for reinstating the code. So, now to do a
> Cygwin build will I always have to manually copy the ipc.new
> code into the directory above it before a build?
No, Huidae just implemented two new parameters into "configure":
--with-ipc use ipc XDriver instead of fifo (for Cygwin)
--with-fifo use fifo XDriver instead of ipc (default)
Huidae - good idea, thanks!
So it shouldn't bother you any more and the IPC code can be
savely developed in parallel.
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
