[GRASS5] r3.out.v5d fixed - G3D rows/cols/depth order
Markus Neteler
neteler at geog.uni-hannover.de
Fri Jan 26 12:00:32 EST 2001
Hi all,
I have fixed the output of r3.out.v5d to produce proper
(unflipped) output for Vis5D.
The export routine is changes from
for (z = 0; z < depths; z++) {
for (y = 0; y < rows; y++) {
for (x = 0; x < cols; x++) {
to
Note: the r3.out.ascii has a *different* way to output.
Still there some the confusion here, but I was successful
to assign x to cols and y to rows. Means: To me the rowcol.bug
stuff was done on G3D.
To be done:
- fix r3.in/out.ascii
- r3.out.v5d exports one row/col/depth *less* than the volume
size in GRASS. There was something with .5 cols/rows/depth.
Any pointer here?
Markus
Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
