[GRASS5] XDRIVER problems
John Huddleston jhudd at lamar.colostate.edu
Fri Jan 26 12:32:41 EST 2001
My fault everyone,
I had put the ipc.new source code into the system.  I thought it
had been tested in the Unix platforms.  I remember seeing an
email from Markus stating that it was faster.
I'll reiterate what I asked Markus offline.  It would be nice
to have a phone conversation with all parties involved.
Email and the day or two delay can only go so far.
Thanks Huidae for reinstating the code.  So, now to do a
Cygwin build will I always have to manually copy the ipc.new
code into the directory above it before a build?
John Huddleston
----- Original Message -----
From: "Markus Neteler" <neteler at geog.uni-hannover.de>
To: <grass5 at geog.uni-hannover.de>
Sent: Friday, January 26, 2001 9:08 AM
Subject: Re: [GRASS5] XDRIVER problems
> Thanks, Huidae,
> for reverting the IPC-changes and migrating them into ipc.new/
> Hi all,
> please try again to compile and use the XDRIVER.
> Markus
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
