[GRASS5] Mac OS X errors
Markus Neteler neteler at geog.uni-hannover.de
Fri Jan 26 08:32:48 EST 2001
Hi again, Jeshua,
On Fri, Jan 26, 2001 at 12:44:01AM -0800, Jeshua Lacock wrote:
> Greetings,
> I just compiled beta 11 on Mac OS X and here are the errors from modules tat I could not figure out (most of these errors have been posted before with previous builds):
> The following modules:  d.colors, i.class, i.ortho.photo, i.points, i.points3, i.vpoints,  get this error:
>    /usr/bin/ld: Undefined symbols:
>    _gtty
>    _stty
no idea...
> src/mapdev/v.in.shape:
>    shp2dig.c:25: header file 'malloc.h' not found
> I got this module compiled before (beta 10)  by using:
> Copying /System/Library/Frameworks/System.framework/Versions/B/Headers/bsd/sys/malloc.h to src/include.
> Now I get the errors:
> malloc.h:257: undefined type, found `u_short'
> malloc.h:258: undefined type, found `u_short'
> The same thing goes for these modules:
> v.mkgrid, v.out.shape, src.contrib/SDTS
mh, no idea as well.
> src/mapdev/v.rmdup:
>    rmdup.c:201: structure has no member named `_shortbuf'
>    make[1]: *** [OBJ.powerpc-apple-darwin1.2/rmdup.o] Error 1
>    make: *** [all] Error 2
Fixed.
> src/raster/r.in.gdal:
>    I can't get the gdal lib compiled.
> src/raster/r.in.png & src/raster/r.out.png:
>    pngfunc.h:12: header file 'pnm.h' not found
>    pngfunc.h:29: undefined type, found `xel'
>    r.in.png.c:197: undefined type, found `pixel'
>    r.in.png.c:200: undefined type, found `pixel'
>    r.in.png.c:207: undefined type, found `pixel'
> I think it's because I couldn't get netpbm compiled.
Andreas, still the header files are not yet uploaded as I
have lost your tarball mail.
> src/raster/r.in.random and src/sites/s.kcv:
>    _lrand48
>    _srand48
fixed both r.random and s.kcv with defined(__APPLE__)
> src/sites/s.random:
>    main.c: In function `main':
>    main.c:128: `drand48' undeclared (first use in this function)
>    main.c:128: (Each undeclared identifier is reported only once
>    main.c:128: for each function it appears in.)
>    make: *** [OBJ.powerpc-apple-darwin1.2/main.o] Error 1
fixed with defined(__APPLE__)
> src/raster/r.mapcalc:
>    _drand48
>    make[1]: *** [/usr/src/grass5/dist.powerpc-apple-darwin1.2/etc/bin/cmd/r.mapcalc] Error 1
fixed as well:
src.contrib/GMSL/g3d/src3d/raster/r3.mapcalc/mapcalc/xrand.c
> > Markus said:
> > You should have in head file:> XCFLAGS          =  -I/usr/X11R6/include
> I do have that in the head file, and I still get the error:
> src.contrib/GMSL/NVIZ2.2:
>    _XKillClient
>    _XSetCloseDownMode
>    _XSetRGBColormaps
>    _XAllocColorCells
>    _XStoreColors
>    make[1]: *** [nvwish] Error 1
>    make: *** [nvwish] Error 2
sorry, no idea.
> src.garden/answers/src.answers/raster/r.fill.dir:
>    Needs fortran??
Yes, but port to C is on the way.
> /usr/src/grass5.0beta11pre1/src.contrib/GMSL/g3d/src3d/raster/r3.showdspf.openGL
>      mkdir OBJ.powerpc-apple-darwin1.2
>      make -f OBJ.powerpc-apple-darwin1.2/make.rules
>    cc -g -O2  -I/usr/src/grass5/src/libes/dspf -I/usr/src/grass5/src/libes/ogsf -I/usr/local/include/GL -I/usr/X11R6/include/GL  -I/usr/X11R6/include -I/usr/src/grass5/src/include  -c new_init_graphics.c -o OBJ.powerpc-apple-darwin1.2/new_init_graphics.o
>    new_init_graphics.c:16: header file 'Xm/Xm.h' not found
>    new_init_graphics.c:17: header file 'Xm/Form.h' not found
>    new_init_graphics.c:19: header file 'GLwMDrawA.h' not found
>    kns_defines.h:4: undefined type, found `GLXContext'
>    kns_defines.h:5: undefined type, found `Window'
>    kns_defines.h:6: undefined type, found `Widget'
>    kns_globals.h:14: undefined type, found `XtAppContext'
You need "lesstif" to be installed (MOTIF clone, see REQUIREMENTS).
> Note that I had to issue a "make real-install" for it to install; "make install" seemed to do nothing.
That's strange and not o.k. (hi Justin :-)
So far my comments,
you may update and try the fixed modules.
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
