[GRASS5] XDRIVER problem
Andreas Lange Andreas.Lange at Rhein-Main.de
Fri Jan 26 08:21:08 EST 2001
Hi 2 all,
i have the mentioned problems with the XDRIVER too. Nothing seems to
work any more on Linux (RH 7.0). Please revert the changes or find the
problem, as i urgently need a working version of GRASS5.0 again!
I'll try to recompile the latest CVS version and report again in the
evening.
cu,
Andreas
Bernhard Reiter wrote:
> On Fri, Jan 26, 2001 at 09:07:34AM +0000, Markus Neteler wrote:
> > On Thu, Jan 25, 2001 at 07:55:07PM +0100, Radim Blazek wrote:
> > John Huddleston has benn uploading the IPC code into XDRIVER
> > from Malcolm Blue (unfortunately without announcement).
> > >From my experience it works well in Linux, but:
> > You have to rebuild most. See the file README.ipc (which is a script
> > as well), it should do the job. After compilation it will run o.k.
> > Or am I wrong? John, please post the changes!!
> If this is causing problem on some platforms, we might be able to
> use CVS to revert to a more tested revision of this code for the
> release. :)
> (Just to make you again aware of the capabilities of CVS.)
>         Bernhard
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
