[GRASS5] XDRIVER problem
Bernhard Reiter
bernhard at intevation.de
Fri Jan 26 04:55:51 EST 2001
On Fri, Jan 26, 2001 at 09:07:34AM +0000, Markus Neteler wrote:
> On Thu, Jan 25, 2001 at 07:55:07PM +0100, Radim Blazek wrote:
> John Huddleston has benn uploading the IPC code into XDRIVER
> from Malcolm Blue (unfortunately without announcement).
> >From my experience it works well in Linux, but:
> You have to rebuild most. See the file README.ipc (which is a script
> as well), it should do the job. After compilation it will run o.k.
> Or am I wrong? John, please post the changes!!
If this is causing problem on some platforms, we might be able to
use CVS to revert to a more tested revision of this code for the
release. :)
(Just to make you again aware of the capabilities of CVS.)
Bernhard
Professional Service around Free Software (intevation.net)
The FreeGIS Project (freegis.org)
Association for a Free Informational Infrastructure (ffii.org)
FSF Europe (fsfeurope.org)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20010126/64b52a47/attachment.bin
