[GRASS5] Mac OS X errors
Jeshua Lacock jeshua at SierraMaps.com
Fri Jan 26 04:15:15 EST 2001
On Friday, January 26, 2001, at 01:36 AM, Markus Neteler wrote:
> thanks for your comprehensive compile test.
> On Fri, Jan 26, 2001 at 12:44:01AM -0800, Jeshua Lacock wrote:
> > src/mapdev/v.rmdup:
> >    rmdup.c:201: structure has no member named `_shortbuf'
> >    make[1]: *** [OBJ.powerpc-apple-darwin1.2/rmdup.o] Error 1
> >    make: *** [all] Error 2
> I have updated this file, please
> cvs update src/mapdev/v.rmdup
> I changed the macro to:
> defined(__APPLE__)
> if it runs o.k., we can use it for several other errors as well.
> So please try to compile the updated v.rmdup.
Markus,
Thanks for your brilliance!  That does the trick.
Let me know when I should update the other (similar) modules.
Cheers,
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
